What Compression?
What Compression?
I've got to replace my shortblock because the rod bearings bit the dust. While its torn down I'm going to send the heads in to get them trued up. I am running a TSP Torquer V2 232/234 600 lift ground on a 112. What would be my best compression ratio for this combo. The new shortblock will have -2cc valve relief and I always run 93 octane Ammaco fuel.
The higher the better generally speaking. Run a .040 gasket and mill the heads down a bit. You have room to play with since you have .100 relief in the pistons. Play with the DCR calculator to come up with specific numbers.
Shoot for 11-11.5:1 and get as tight of quench as you can through a thinner gasket and milling the heads. More compression always helps power everywhere and driveability. The main limiting factor in your case will be octane.
Jason
Jason
Jason
Jason
