Part Number
Part Number
I need the lower shift boot, that actually goes on the base of the shifter, for my 98 Trans Am 6-speed. Does anybody know what the part number is for the black boot that is shown in the picture below. I can't seem to find it anywhere.
I did a search on the part number that you gave me, 10267518 and it's showing that is the rubber boot that bolts into the floor pan. I need the one as shown in my picture which just slides onto the top of the shifter to seal the top of it. Then the part that your describing slides over the shifter handle and bolts into the floorpan.
Originally Posted by 2xLS1
Item 98 is listed as BOOT, M/MTRNS CONT LVR, (BOLTS TO UNDER BODY RUBBER) 97-02 F (MM6) 10267518
If that is not it, it is probably sold as part of the shifter and not serviced separate.
