Windshield washer fluid Jet doesn’t work
Old 02-26-2007, 05:28 PM
ls1owner4life's Avatar
Default Windshield washer fluid Jet doesn’t work
The passenger side windshield washer jet does not spray wiper fluid. When I bought my ‘02 Camaro it had WATER in the wiper fluid container. I understand that pure water can cause calcium buildups and deposits in wiper fluid lines. What do you recommend I can do to make it work?
Old 02-26-2007, 05:47 PM
Gun5's Avatar
new one or get a paperclip or something thin to stick in it..
Old 02-26-2007, 05:49 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
I have used only water in mine since the first time the washer fluid was used up from factory...no problems here, although I have only used it maybe 30 times. We also only have soft mountain runoff water here, so that might be why.....stick a pin in the end of the nozzle, see if that works..might just be gummed up from road grease/dirt/crap.
Old 02-26-2007, 06:00 PM
Formula413's Avatar
Take a little twist tie for plastic bags and strip off the paper/plastic coating to reveal the bare wire, it's very thin and bends easily, great for getting in there. About a month after I got my car the sprayer wouldn't work, opened up the resevior to see a solid brick of ice. It was only 20 degrees out, so it must have been about 90% water in there. One of the things I would love to thank the previous owner for.
Old 02-26-2007, 06:04 PM
2001NBMZ28's Avatar
It's not just a loose/cracked hose and just spraying under the hood is it?
Old 03-06-2007, 07:15 PM
trans-am nut's Avatar
Mine wouldn't work as well and it was the motor. Just slips out after you unplug it. Maybe you can switch with a buddy to check before you waste money
Quick Reply: Windshield washer fluid Jet doesn’t work
