anyone use wait4me for harness work
Old 02-26-2007, 09:54 PM
jimmyp's Avatar
Default anyone use wait4me for harness work
Im getting the harness/pullout from an 03 chevy truck 4.8L. I dont have time to go ahead and start modding the harness myself. Ive heard that wait4me does harness cleanup and retunes for $300 which I can live with. Just looking for any experience with this.
I am simply using this engine to go onto a dyno test stand.
Old 02-26-2007, 11:30 PM
rat_rod_russell's Avatar
I have 3 different LS harnesses from them and not problems expect for the one i changed the pullies on and had to move some cables the hard way.
R^3
Old 02-26-2007, 11:39 PM
sawzall wielding director
G-Body's Avatar
I did my own harness, but Jesse did the tuning on my computer and I am very happy with the tune. His rates are very reasonable plus he was able to set me up with a tow/haul mode, and he reset my tach output and speedo output (the output from the computer to the instrument cluster that way I could use that signal to control my ancient cruise control which was looking for 2000ppm not the current 4000ppm standard)
Old 03-02-2007, 04:24 PM
ROBSQUEZN's Avatar
Default harrness
jessy at wait for me his work on ecm & wire harnesses is great i use him for all me ecu/wire stuff good guy great work
Non-sponsor info removed.
Old 03-02-2007, 04:51 PM
765joey's Avatar
Speartech did my harness. His name is John Spears. He does excellent work and very fast turn around. I was very happy with his price's too.
Old 03-02-2007, 06:20 PM
Jake@EPP's Avatar
+1 For John Spears @ Speartech!
Old 03-21-2008, 03:05 PM
4.8LGMC's Avatar
Default PCM and HARNESS
I need an engine wiring harness. All I need is the stuff for the injectors, power, knock sensors, crank position sensor. I'm building a twin turbo LS1 for my 77 trans am drag car. what else would i need for the engine harness?
Old 03-21-2008, 03:32 PM
LS1 Tech Veteran
Steve Bryant's Avatar
Wait4me is a good guy as is John Spears of Speartech. I don't think that you could go wrong using either one.
Steve
Old 03-21-2008, 06:23 PM
TCR-01's Avatar
Jesse has done great work for me. Customer service is great!
Quick Reply: anyone use wait4me for harness work
