D/S ballance ?
Changing U Joints--D/S ballance ?
Will changing out from a 1350 u joint to the 447 joint to fit the D/S - rear yolk through the ballance off? I would think that it will and need re-ballanced but checking to see first. Thanks
LS1Tech Sponsor
Anytime a u-joint is replaced the driveshaft should be balanced. The OEM's shafts are not that good to begin with so I would have it checked just for good measure.
