Need to find the TPS wire!
Damn uhh look at the pins....i just did mine do a search and you will find it oh and u proably would want to wire it right up next to the pcm i had a bad signal wireing up next to the tb... its the purple wire by the way.
Originally Posted by 99blancoSS
Link didnt work. You need it for a window switch? I tapped into it right off the TB. Mine was brittle though and I had breakage issues so Tom replaced the connector and spliced back far enough to where we found good wire to connect to.
What pins do I need to look at? I don't understand what a pin is.
Jon, I'd be carefull following the above advice without varifing it yourself. I'm not sure if the TPS wire colors are the same on the corvette's and F-bodies. Could be bad if you just blindly go and attach the switch to some random colored wire.
I have a wiring diagram at home I'll try to find.
Originally Posted by 00Vette
The purple wire coming from the PCM? And the PCM is in the passanger fender well correct?
the wireing diragram will explain all that to you... its proabably pretty hard to find and since ls1s use the same pcm i dont know why the color would be any difrent but you need to know the pin number for shure because i am not exactly shure if its the same as an f-body........do a search.
Is that correct?
