Brake line question
Old 02-27-2007, 11:10 PM
Hassassin00's Avatar
Default Brake line question
When your bleeding your brake lines do u need to let the air out of all four lines or just the one on an f-body?
Thx
Old 02-28-2007, 02:55 PM
camaroguy26's Avatar
if you're doing it while changing brakes just bleed at the calipers you messed with. If you're flushing the system start at the rear (not sure if it's right or left first) then do the other rear and finally the fronts.
Old 02-28-2007, 04:08 PM
2001NBMZ28's Avatar
Good opportunity to flush the system - bleed RR, LR, RF then LF. Don't let the level drop too far....
Old 02-28-2007, 04:16 PM
Torque_Wrench's Avatar
Bleed em' all friend.
