Easiest wayto track down a vacuum leak?
What is the easiest way to track down a vacuum leak on my car?
Finally got some time and some down time with my car and I think I have a vacuum leak somewhere on the car but not sure how to locate it or find out if I have one at all.
Thanks
Thanks
Originally Posted by slow67
With the motor off, grab a buddy that is a smoker. crack the throttle and stick a hose inside the TB, and tape it off. Have smoker buddy blow smoke into the engine. Watch for it. Of course do this in a non-windy and well lit area
Just don be smokin none of that wacky weed.
http://www.youtube.com/watch?v=8R_jcXEelqw
Originally Posted by reject
yup yup slow67 is right, it's faster and easier to look for a cloud of smoke than trying to hear for a hiss. they also make a smoke machine just for this kind of problem.... but watching a buddy trying to blow for very long is funnier/y lol
I think the quick and cheap way is the use a can of spray carb cleaner.. spray a little (enough to soak the area) around each of the vacumn area that you suspect to be a leak.. if the RPM change.. you found your leak. PCV, Power Break line, intake manifold, TB Gasket ... etc..
This is an old trick that is used for Carb cars but work for EFI too.. been used as long as I can remember.
