flywheel to crank?
clutch/pressure plate to flywheel?
trans to bellhousing?
bellhousing to block?
trans mount?
shifter bolts?
trans case bolts? (rebuilding???)
flywheel bolts get 72lbs, PP bolts get 52, as for sequence you should be fine just doing a cross pattern and torque the bolts in 3 steps instead of just one.
