LS1/LSX blocks, heads, cams, manifolds, and rotating assembly: HELP!
Old 02-28-2007, 11:51 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Question LS1/LSX blocks, heads, cams, manifolds, and rotating assembly: HELP!
Just making sure I have my bases covered. I'm doing an article for Fastest Street Car Magazine on the LS1/LSX style set-up, and we'll be covering the following areas: Blocks, heads, cams, manifolds, and rotating assemblies.
These are the companies I currently have listed. If you know of another, please post up!
I have the following manufacturers for blocks:
GM, World Products and Dart.
I have the following manufacturers/suppliers for heads:
RHS, AFR, Edelbrock, GM, World Products and Dart.
I have the following manufacturers/suppliers for induction/manifolds:
Wilson Manifolds, Comp Cams/FAST, Hogan, Weiand/Holley, and GM.
I have the following manufacturers/suppliers for cam & valvetrain:
Jesel, Comp Cams, T & D, Manley, Crane Cams, Lunati, and Edelbrock.
I have the following manufacturers/suppliers for rotating Assembly:
Lunati, GRP, and Eagle.
Please post up ASAP any others you know with a contact (if possible), and I thank you for the help!
Derek
Old 02-28-2007, 11:56 AM
getusum's Avatar
I would put the tea trick flow 225 heads with the others you have mentioned
Old 02-28-2007, 12:08 PM
Stang's Bane's Avatar
Heads+TFS &AllPro
Cams +cammotion
Intake manifold + Beck
Rotating assembly Callies cranks and rods and Diamond pistons
Old 02-28-2007, 12:10 PM
11 Bravo's Avatar
Harrop intake
http://www.harrop.com.au/root_folder...fd7022-00.html
Old 02-28-2007, 12:27 PM
Phoenix 5.7's Avatar
ETP heads, and GM rotating assemblies(LS7 crank/TI rods)
Old 02-28-2007, 12:41 PM
ROCNDAV's Avatar
Scat also makes LS1 Cranks. I dont know which sponsor carries them though...
http://www.scatcrankshafts.com/
Quick Reply: LS1/LSX blocks, heads, cams, manifolds, and rotating assembly: HELP!
