P.T.V. Clearance on a LS1. Am I pushing it?
I have a LS1 with a stock bottem end. I'm putting LS6 heads that will be ported and polished only, stock valves and no milling done. Plus a TSP Torquer V2, rocking a set of Crane Cam shaft mount roller rockers 1.7:1. I ordered a pair of Cometic .040 head gaskets. Am I safe, or will I need to have the pistons flycut? I know im safe with stock GM gaskets which I have, but I am always looking for more.
thanks, I will check it to be safe, I just wanted to see if any one else had any first hand experance with the same setup, one more question will that change my compression ratio any
the .040 gasket takes away ptv but you should be okay. be careful though because aftermarket rockers are true ratio while stock have a tendency to not always be accurate.
