JGS Wastegate Selection
I want to make sure that i don't under wastegate my car, it'll be running a Forced Inductions S595 Through a 411ci Iornblock.
Will a 50mm JGS wastegate work at low boost or should i step up to the 60mm
I know Jose has said that he is running a 40mm on his 88mm turbo and has no problem keeping it down.
I need som opinions so i can order the remaining parts anf tubing to get it done,
