What Happens if you drive with the Gas Cap Off?
Old 03-01-2007, 01:05 PM
BrianMSmith's Avatar
Default What Happens if you drive with the Gas Cap Off?
I did this a couple weeks ago, probably drove 20 miles with the cap off. What does this do to the car?
Old 03-01-2007, 01:07 PM
Z28LS1camaroguy's Avatar
causes the SES light to come on, it causes unusual pressure to no pressure in the cas tank. Just put it back on and the SES light should go away if your SES light is on.
superchargedbandit's Avatar
Not Good
Old 03-01-2007, 07:42 PM
jay_99z's Avatar
Originally Posted by superchargedbandit
Not Good
Good answer.
Old 03-01-2007, 11:17 PM
zspot98's Avatar
Not Good
Driving w/ the oil filter off is not good. Driving w/ the gas cap off, not that big of a deal.
Old 03-01-2007, 11:49 PM
pHEnomIC's Avatar
Shouldnt have hurt anything, u prob lost some gas due to evaporation though and if the ses was set, just pull the pcm fuse for a couple mins.
Old 03-02-2007, 12:10 AM
Grimes's Avatar
you will be fine. just screw the cap back on
Old 03-02-2007, 08:23 AM
pewter01z's Avatar
It will cause spontaneous combustion and your car will EXPLODE!!! j.k.
Old 03-02-2007, 09:40 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Exactly
Old 03-02-2007, 09:55 AM
LSWon00's Avatar
Spider Monkeys will take over earth now....thanks alot.
Old 03-02-2007, 11:11 AM
nomorews6's Avatar
i think it will just cause a lot of people to laugh at you (don't ask me how I know)
Old 03-02-2007, 11:27 AM
eallanboggs's Avatar
The EPA says your fuel system must pass an EVAP test. The system gets pressurized during the test, but you cause the test to fail when you leave the cap off. The EPA doesn't want gas fumes getting into the atmosphere and ruining the ozone layer. I'll bet the EPA has never been in the pits when a top fuel motor was started. They'd have a fit.
Old 03-02-2007, 01:06 PM
YUP, that fixed my SES problem. could be psychological, but I swear the car ran a bit rough too. Twice now I've not put the gas cap back on correctly.
Must be that getting out of bed at 4am to drive to work thing....though it's nice being home and done for the day by 2pm.
Thanks, and I hope I entertained everyone
Old 03-02-2007, 01:33 PM
01ls1lover's Avatar
Oh you did, Thanks for the laugh!
Quick Reply: What Happens if you drive with the Gas Cap Off?
