first tune was HP can 2nd tune LS1 edit?
my first tune for LTs & cam was HP tuners I'm planning heads & manifold can the new tuner use LS1 edit on top of the HP tuner?
I'm thinking the first tune will have to be erased then all redone w/ LS1?
also I'm planning a bigger torque converter do'es the tuner tune for this also, thinking mite be better to do hardware at same time then tune?
Thanks
Thanks
yes, so long as the previous tuner didn't lock the tune
regarding the converter, it can be tuned (bigger converters are loser so shift point changes and rev limiters sometimes need to be adjusted, if you're stock trans with no shift kit they can raise line pressure etc...)
