Fueling & Injection - what size fuel line
lt1mc
03-01-2007, 08:11 PM
doing a lt1 swap into my 86 monte. i need to know what size fuel line i need to go with so that i can get a sump with the correct sizes. im looking to do about 400ish rwhp. thanks everybody
DuronClocker
03-01-2007, 10:36 PM
If you're going to run all new line and plan on big upgrades in the future, get the sump fitted with at least a 10AN fitting, if not a 12AN fitting. I think I'm going to run a 10AN line for the time being but also putting a 12AN fitting in the tank with a cap on it. That way I can easily drain gas out of the tank, and I can upgrade to the 12AN line if I ever need to and cap the 10AN line then :)
lethal93ta
03-02-2007, 02:03 AM
400HP you could get away with a -6 line after the pump but I would suggest a -8 line after the pump and a at least a -10 to go to the pump from the tank, I put a -12 line on mine from the tank to the pump and a -8 to the engine.
1QUIKWS6
03-02-2007, 04:07 AM
I had a 86 Grand Prix with 383 and Paxton supercharger - ended up running a 1/2" aluminum line for feed and 3/8" line for return. This engine was carbed so I ran an electric inline with boost referenced regulator. Never had any fuel starvation problems.
-Jay-
lethal93ta
03-02-2007, 08:12 AM
1/2 inch is the same as -8 line, -6 is 3/8
1QUIKWS6
03-03-2007, 06:27 PM
That's true - I just didn't want 30ft of braided SS hose running under my car - so I used the aluminum line for feed and stock steel feed line for return.
DuronClocker
03-03-2007, 07:45 PM
I've also debated running some 1/2" aluminum piping. Its priced VERY reasonably. How easy is it to bend?
lethal93ta
03-04-2007, 01:39 AM
its not to bad to bend just dont expect to make a 3 inch turn with out kinking it, 6 inch is about the most I ever got to bend with out a kink
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
