what psi et streets?
Old 03-02-2007, 09:39 AM
dameter21's Avatar
Default what psi et streets?
what PSI should I set for my ET streets at the track. 2000 A4 TA, stock stall/gears. bolt ons.
Old 03-02-2007, 02:12 PM
dameter21's Avatar
anybody
Old 03-02-2007, 02:13 PM
superchargedbandit's Avatar
15 -20 Depending On Air Temp.
Old 03-02-2007, 02:52 PM
CrimeSScene's Avatar
I tried mine at 12 lbs last time I was at the track (61 degrees out) and they still didn't hook for ****. Couple of guys at the track told me to try 10 lbs, but I had already gotten pissed off and loaded my car back up. It is like superchargedbandit says in that it will vary on temp. Just start high and lower the pressure until they start hooking. I personally think 10 lbs is a bit too low for my safety but to each their own.
Old 03-02-2007, 02:56 PM
You Have To Heat Them Up Real Good Also.
Old 03-03-2007, 03:43 PM
rickssz's Avatar
Are you talking drag radials or slicks?
Old 03-03-2007, 03:44 PM
SiL3NtXWS6's Avatar
he is talking about ET streets, which are the non radial version.
Old 03-03-2007, 03:45 PM
I Run Mine At 15-18 Depending On Air Temp
Old 03-05-2007, 12:49 PM
JakeY2KZ's Avatar
You're going to bog very heavily if you drop them to anything under 20psi. Your stock stall can't handle that type of tire and will probably net you worse times then what you can run on a stock tire/drag radial.
I'm telling you this b/c it did the same thing to me when I was on a stock stall/2.73 gears and bolt ons.
Old 03-05-2007, 02:33 PM
pontiac's Avatar
I used to try the 13lbs and keep droping them until i got to 8psi haha wow thats a ride. but then someone told me try alittle more air inthem casue my car was heavy then i tried 16 and came down to 13.5 and thats where i run the best
