Flycut pistons for MS4 with PRC 5.3 2.5's in TSP shortblock?
Old 03-02-2007, 01:46 PM
Mike94ZLT1's Avatar
Default Flycut pistons for MS4 with PRC 5.3 2.5's in TSP shortblock?
Im looking at having TSP build an engine for me, I am interested in the 347 short block with the Diamond -2cc pistons, upgraded rings, ARP hardware blah blah blah and using a set of their PRC 5.3 liter stage 2.5 heads, along with their Magic Stick 4 camshaft. Would I need to flycut the pistons for this combo to work? I was thinking of shaving the heads a tad...
Old 03-02-2007, 02:20 PM
Z28LS1camaroguy's Avatar
im pretty sure you dont need to flycut with the MS4 cam
Old 03-02-2007, 02:36 PM
Thimble's Avatar
-2cc pistons means they're already notched...so no, you shouldn't need to remove additional material.
The MS4 will fit stock heads w/o flycutting...PRC 2.5's have larger valves which reduces clearance, and I believe TSP has said the MS4 will not clear the 2.5 heads w/o notching.
Old 03-02-2007, 02:43 PM
i knew it was one of those lol, either way good setup post some numbers once you get it on the car.
Old 03-02-2007, 02:44 PM
marv's Avatar
I'd have to agree with you on that one. Seems like I've seen them run the MS3 with those heads, but not the MS4.
Old 03-02-2007, 02:50 PM
lt1formula2000's Avatar
I would talk with TSP about it, you could always get a little more relief in the pistons
Old 03-02-2007, 08:38 PM
Mike94ZLT1's Avatar
Haha, I have been but Jason takes 2 days to respond to PM's! He's been very helpful though, I'm really kinda hoping I do have cracked rings and I need a new engine!
Quick Reply: Flycut pistons for MS4 with PRC 5.3 2.5's in TSP shortblock?
