LS1 feels like 30HP not 400HP
Hi Guys, Im new. I have a 2002 Firehawk that was dyno's 426HP to the wheels. Sad thing is I cannot figure out a problem now. A couple days ago I was in 1st gear and got on it, and my lights flickered and felt like I was in 3rd. There is not check engine light or DTC codes posted. So scanning the computer wasnt a problem. It starts good, idles good, but when you give it gas, you can tell there is no power. Almost like it was running on 7 cylinders. Any suggestions?
Thanks,
Mav
Thanks,
Mav
Originally Posted by Alex L.
I had a similar experience and a piece of plastic was stuck on my maf sensor wires. Check your maf
wires, maf, throtle body epoxy'd shut? HA, no really, check your maf. Start car, let idle, and tap if after visual inspection nothing is found. Then, if that still does nothing, then unplug it and see if anything changes, i.e. idle up or anything
Actually I just pulled the fuel filter and I noticed small amounts of water. Looks like I have water in my gas tank. Damn... Guess this will be a weekend fix for me. Thanks for all the help.
