Starter Issues After Header Install?
I've had an issue for several months now where the longer I drive my Firehawk, the harder it is to start.
It all started back after I got my Dynatech Supermaxx header system installed. There's a high crank, less than one year old battery installed, too.
When it's cold, it cranks right up like a demon. The more I drive it, and the hotter the car gets, the harder it is to start.
It's not a whining issue like with a battery. It just won't turn over when you turn the key the first time.
The consensus among those I spoke with locally was that the solenoid was becoming heat soaked due to the new source of heat coming off of the headers.
I had a thermal wrap installed over the starter today by the same shop that did the headers/plugs/wires install hopingo to eliminate the problem.
But as soon as I left and stopped somewhere else, it did it again.
It's like you have to give it a little bit extra effort to get it going.
Again, this is after the car has been driven and heated up, then cooled down. When completely cold, it starts up like a champ.
Any ideas on what this could be? I don't want to go into guessing at changing the starter etc. etc. if I don't have to.
Does the solenoid engage slowly...?
Does your starter slow...?
Are you sure it's not some other problem (plugs, wires, sensors, injectors, fuel pressure, rich/lean, ground connections, etc...)...?
I have JetHot coated Supermaxx's and don't have this problem (hot or cold, I barely touch the key to the start position and it fire's right up).
The heat shield was just installed today. I only had the chance to drive it and restart it twice since the install, so I'll need a few more days to see if it helped. But I was told the shield would solve the problem. Sure hope so...?
