Engine Swap and CA Smog?
Old 03-02-2007, 06:26 PM
SSilver's Avatar
Default Engine Swap and CA Smog?
so some guy on a jeep forum is telling my brother that he needs to run the 4l60e tranny to pass smog. I think the guy is full of crap.
From what I understand you just have to retain all the smog stuff and it doesn;t make any difference what transmission you use....I could be wrong.
SSilver's Avatar
just for reference its a 1978 Jeep Cj7 with a 1999 5.3 and the stock jeep t18 tranny.
Old 03-02-2007, 10:38 PM
ROBSQUEZN's Avatar
Default smog
u can use any tranny u wish.. just built a mazda rx7 ls2 with a 6 speed it was an auto mtr & car
Old 03-03-2007, 02:03 AM
danglerb's Avatar
I started a fairly long thread here a few months ago on Calif Smog, https://ls1tech.com/forums/conversions-swaps/603042-california-smog-legal-swaps.html
Smog rules go by the donor car, and if you pick one with a automatic transmission that has the shifting controlled by the EMU things could get real sticky for you. More common is that the tranny sends some signal to the EMU about the gear and speed and you might have to make a "box" that creates that signal. You will not pass if the EMU is showing any error codes. Good luck, and its lots of YMMV.
Quick Reply: Engine Swap and CA Smog?
