No Clue what this could be?
Im hoping that someone could tell me what they think could be happening to the clutch. Trying to get it figured out before I pull it out of storage.
Here are the examples of what happens
When I am at WOT and I put the clutch in and shift say from 2-3 or 3-4 it seems like the clutch doesnt want to pop back up, I have to manually lift it back up with my foot from underneith.
Next example is when Im stopped, gear is in neutral, I rev it up put the clutch in, and it doesnt release back up. Or same thing like Im in first gear, at a stand still, clutch in and rev, release the clutch, it doesnt release.
What do you think it could be, or what is going on. Im stumped, but Im leaning on a pressure plate or maybe the peddal is just sticking. Im not sure. I need some help. Thanks for all the help.
mine was the slave cylinder. so i replaced it with the supposed updated slave. and it still would stick sometimes (rarely) so i replaced the master cylinder and now the thing is perfect. i had the exact same problem.
u need a new master cylinder and its a bitch to get the bolts through unless u have small hands and u need to make sure u bleed it reall good took me a while but i finally got it (so many methods)
Thanks guys for all the help. I think Im going to try the easiest thing first and see if bleeding the system works first. If it doesnt Ill replace the master cylinder. Do you think it would even be worth getting a new clutch/pressure plate or not. I plan on doing Heads/Cam in the near future? Thanks again for all the help.
Mike
Mike
I Would Think About A New Clutch. If You Are Going To Do A H/c Soon. The Pedal Sticking, Is You Need A New Master. Then You Need To Do The Drill Mod And Bleed It Good. That Will Take Care Of Your Problem.
Get one from NAPA. It doesnt come with a new resivor or braided line but you can reuse the old resivor and braided line. It only costs $50 and has a lifetime warranty. I replaced mine last week. Just make sure you get the one for a 2001 or 2002.
Originally Posted by Smokin00WS6
what is the difference for the 01 02. Its ok that Im a 2000?
