PCM Diagnostics & Tuning - Abs Inop, Brake Light, Tcs
chris77
03-02-2007, 08:31 PM
anyone know what sensor controls these 3 things. latley all three lights have been comming on. thanks.
chris77
03-03-2007, 09:09 AM
anyone
6-Speed Terror
03-03-2007, 09:30 AM
i have heard that the sensor on the back of the front brake rotors can go bad. i say chek the wiries and make sure they didnt get cut or damaged. there is one on the differential but i think that one will only make the abs inop go on. hope it helps
TAQuickness
03-03-2007, 10:26 AM
I've also seen it be the result of loose grounds - particularly the one on the back of the left cylinder head.
pddye
03-03-2007, 10:37 AM
sounds like dirty rings or magnets or a ground problem.
chris77
03-04-2007, 10:35 AM
thanks guys i will check those things out.
4thgenz
03-04-2007, 03:55 PM
well i dont have tcs on my car. but my "brake" light and "abs inop" lights are both on. sounds like im having the same prob. also though...mine doesnt like to start for some reason. i thought that the abs inop light was like a back up to the "ses" light? thanks guys
http://i11.tinypic.com/44r85c4.jpg
chris77
03-04-2007, 04:09 PM
well i figured it out. it was the gorund where i have my line-lock, nitrous,and window swith hoked up to. thanks for the info guys
4thgenz
03-04-2007, 05:04 PM
yip...figured mine out too! my + battery terminal was loose. starts just fine..and no more lights.
2_wacko
03-17-2007, 03:16 PM
I have this same problem the lights where off before then after installing the linelock they came on wtf?
sic2001
08-05-2007, 11:19 PM
Imhaing this problem toor ight now, I dont have any of those things you mentioned but I do have alot of audio stuff so where was your ground problem exactly?
jmill96Z
08-06-2007, 05:26 AM
Is there a way to tune these out (ABS) other than the tape mod or clipping wires?
Sideways240sx
08-06-2007, 08:28 PM
Could a gear and not having the speedo adjusting, or running a slick maybe cause it? my traction control light doesn't come on, but abs inop, and brake light come on while crusing at highway speeds for a while. It never did this before, but i just did a 4.10 gear, and mt et streets.
If the car is going slower like 45 and under, it never comes on. Thanks, Chris
3.4camaro
08-07-2007, 10:30 AM
Check that one, and the ones on the driver's side shock tower.
sic2001
08-19-2007, 11:06 PM
I cant find a ground on the back of the left cylynder, They just replaced both cats on both sides so that makes sense but I cant find it!
itchygomey98
08-20-2007, 05:43 AM
Check the grounds. There are grounds in plain view on each side of car. Not the ones attached to the engine.
