383 stroker kit - do i need bigger injectors and??
Old 03-03-2007, 12:49 AM
nomorews6's Avatar
Default 383 stroker kit - do i need bigger injectors and??
will i need to get bigger injectors and/or another fuel pump if i do a 383? Also, what kind of power should/could i see?
ported 90/90 fast
230/234 595/585
prc 2.5r 5.3 heads
LT's
Pulley
already put approx. 420rwhp through a4 in 346
Old 03-03-2007, 01:31 AM
PREDATOR-Z's Avatar
Yes and Yes, I recommend to get 42lbs and PnP Racetronix 255 pump setup with harness.
Old 03-03-2007, 06:59 AM
black01_WS6's Avatar
but yes you need bigger injectors,and reccomend what predator-z said.
Old 03-03-2007, 08:12 AM
nomorews6's Avatar
hmmm - do i perhaps need those things now then as well in a 346 making 420rwhp?
Old 03-03-2007, 08:40 AM
PREDATOR-Z's Avatar
Only way to tell is from live monitoring. But it would'nt hurt
Old 03-03-2007, 11:36 AM
frodo84's Avatar
Do you think 30# SVO injectors are big enough? I have one in progress also, didn't think I'd need a fuel pump upgrade...
Old 03-03-2007, 11:40 AM
PREDATOR-Z's Avatar
Yes SVO 30s are enough. With proper fuel pressure and supply I've run them till well over 500rwhp.
Old 03-03-2007, 11:44 AM
frodo84's Avatar
thanks for the reply, do you still recommend a fuel pump upgrade with the 30# SVOs?
