Throwing code for MAP sensor after intake install....
Old 03-03-2007, 08:09 PM
C Murda's Avatar
Default Throwing code for MAP sensor after intake install....
ok so i installed my fast 90 intake and now im throwin a code for my MAP sensor....has anyone ever had this problem? why is it doing this? also now my car doesnt like to start the first time i turn the key...itll fire but then die?
Old 03-03-2007, 08:45 PM
C Murda's Avatar
anyone? i remember when i was reinstalling the map sensor into the fast manifold it went in loosly? on my original ls6 intake, the map sensor had a little bracket to hold on to so it was secured in the manifold... would this be the problem?
Old 03-04-2007, 02:32 AM
That's what she said...
TheBlurLS1's Avatar
It may have popped out. What you can do is go to the stealership and buy just the little rubber part that's on the MAP sensor. The sensor itself is like $90, but the rubber piece is only like $5. It will fit MUCH better after this.
Make sure it's plugged in right too.
Old 03-04-2007, 03:13 AM
Ferocity02's Avatar
What code is it exactly?
Old 03-04-2007, 01:36 PM
C Murda's Avatar
ya its plugged in right unless the connector is capable of being plugged in upside down? i cant see it but it went in fine. and the map sensor itself is still in the manifold so it didnt pop out. but yea i will go down to the stealership monday as i do need a few things.
Old 03-04-2007, 03:50 PM
Prophecy's Avatar
you can get the map sensor @ autozone and switch the rubber piece off that one then return the part you bought because they are dumb.... Dont run the car like that though.
Old 03-04-2007, 05:08 PM
C Murda's Avatar
haha thanks chuckles.....i think ill do that tomorow then.
Old 03-10-2007, 01:07 PM
C Murda's Avatar
ok so i finally got around to pulling my old MAP sensor out for inspection and when i did it was wet!? like the tip that is inside the manifold was wet with what smelled like gasoline....is this normal? what would have caused my map sensor tyo get soaked in gas inside of the intake manifold?
Old 03-10-2007, 03:07 PM
C Murda's Avatar
anyone?....so i figured the only way this can happen is through the EVAP system which plugs into the front of my manifold....but last i heard it wasnt supposed to release this much gas to cause my MAP sensor to fail right?
Old 03-10-2007, 03:55 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Your EVAP system should only be releasing vapors, so I'd discount that one.
Old 03-10-2007, 05:13 PM
C Murda's Avatar
well if it only were releasing vapors why am i having this problem? i mean i havnt even started the car in 2 days and i pulled the MAP today and it was soaked in gas...
Old 03-11-2007, 03:08 PM
C Murda's Avatar
anyone know? i have a new one to put in and i dont want to do it if im just gonna smother it in gas and it fails on me too
Quick Reply: Throwing code for MAP sensor after intake install....
