Signature Testing & Design Test your sigs here!
Quick question for the sig nazi's
Old 03-04-2007, 11:48 AM
RaNsOm's Avatar
Default Quick question for the sig ****'s
Show me where it says only 1 image per sig? The link you keep throwing in my sig says nothing about # of images. My main image was 437x150 pixels, yet it was removed and emphasized that 500x150 is the limit?
Not only that, but the 2nd image was even smaller! 425x47 to be exact.
You might want to add a special rule that only 1 image is allowed. Because of the lack thereof, I now have 2 warnings and I'll get a 'vacation' if it happens again
Old 03-04-2007, 11:55 AM
Administrator
unit213's Avatar
My take on this is that multiple images are fine as long as they don't exceed
500x150 total and that they are positioned next to each other instead
of underneath one another.
Old 03-04-2007, 02:18 PM
cyphur's Avatar
500x150 is the total limit size. Lets break it down....
two images, both 250x75, is fine. or, 300x100 and 200x50. or, well, you get the point.
yet.... 437x150 + 425x47 = 862x197. Which is a hell of a lot bigger than 500x150.
Make sense?
Old 03-04-2007, 04:04 PM
((((((Administrator))))))
CRAGER's Avatar
Did you read the sticky up top???
https://ls1tech.com/forums/signature-testing-design/356036-signature-faq.html
"The size limit for signature images is 500 pixels wide by 150 pixels high."
You can have 20 pics, as long as the total number does not go over 500 x 150.
Hey I had to do it as well because I have a link to MTI in my sig, and sponsors get the axe as well. Nobody can get away with going over 500 x 150 total size.
Hope that helps you underatand it better.
Peace,
Craig.
Old 03-04-2007, 04:12 PM
CRAGER's Avatar
Here is another example of a member in the same boat as us:
XtinctZ28
https://ls1tech.com/forums/member.php?u=40356
98 Z28 - Black, M6
- Does it look stock? Does it sound stock? Then it probably isnt stock -
His main sig pic is 463 x 125, and the FQuick link it 350 x 19. Total height is 144.
Peace,
Craig.
Old 03-17-2007, 01:49 PM
RaNsOm's Avatar
oh ok, so as long as I crop the height down in my main sig, I can put the gamertag picture/link back underneath it as long as the 2 totals dont go over 150pixels, gotcha.
Old 03-18-2007, 02:08 AM
CRAGER's Avatar
Yes sir, you got it!
Peace,
Craig.
Old 03-26-2007, 04:37 AM
StrobinSS's Avatar
Do moderators have to follow this rule? If so, go check your moderators. One is 8 pixels over
Old 03-26-2007, 07:05 AM
CRAGER's Avatar
Yes we do as well, look at mine. There are a few other moderators that did what I have done. Reduce main sig pic to allow the other image to fit.
Even sponsors don't get away from these rules.
Way too many mods for us to go through, but if one of the sig mods comes across him/her we will straighten them out as well.
Peace,
Craig.
Old 03-26-2007, 04:53 PM
cyphur's Avatar
Crager for President, 2008!!!!!
Quick Reply: Quick question for the sig nazi's
