Need info on these cams...
Old 03-04-2007, 06:53 PM
CALL911's Avatar
Default Need info on these cams...
I'm looking for a cam thats going to make some great power with a nice lobe to it, but not kill the mid range as I want to stay with the stock 3.42's. Mods on the car will be LT's, Y-pipe, catback (not sure of the exact ones yet), Whisper lid, FAST intake, and a good tune after the cam install.
The cams I have been looking at to fit my desires are the G5X1, MS3, MS4, T-Rex, and XE-R cams. If anyone has any suggestions with details that would be great. Video's would really be ideal if anyone has anything like that.
Thanks in advance.
Old 03-04-2007, 07:43 PM
redtail2426's Avatar
with 342 gears you can forget about the ms3,ms4 and trex..the g5x1 would be a good choice out of what you have..
Old 03-04-2007, 09:16 PM
CALL911's Avatar
Is that just becuase the MS3, MS4, and T-Rex kill your mid/low range too much?
Old 03-04-2007, 09:22 PM
00BlueTA's Avatar
If you want your car to run well you need different gears like 4.10
Old 03-04-2007, 09:46 PM
Wezie F Baby's Avatar
Which cam all depends on your plans for your car. Is your car a DD or will you be hitting the track much?
Old 03-04-2007, 09:54 PM
ssfast99's Avatar
yah t-rex and gears like that need big gears and they are not that good with low mid range. they are top end cams.
Old 03-05-2007, 06:18 AM
CALL911's Avatar
Although it will be taken to the track a handfull of times a year, it will mostly be a DD. Yeah, I'm not looking for a strick top end cam only.
Old 03-05-2007, 07:08 AM
moeZ28's Avatar
Then definitely forget the TREX...I have the Version 2 and it really doesnt start to pull till around 4200rpms. I am actually about to swap mine out to get a more usable power band. My car isnt a DD, but I drive it alot, 4 times a week maybe...and it will see the track as much as it can, but i work alot so that wont be alot. I love how the TREX pulls up top, its a true animal, but I want something a little easier to drive around on, and makes more usable power. You will definitely not want anything bigger than say a G5X2, and that is pushing it a little.
Old 03-12-2007, 07:36 PM
bgardner88's Avatar
So if i get the G5X2 with ported and polished LS6 heads should i change my rear end??? ive got a 6 speed with 3.42's. any suggestions
Old 03-12-2007, 07:47 PM
Studytime's Avatar
You should change your rear-end regardless.
Ben T.
