Covering drilled holes in throttle body?
My throttle body has 2 holes drilled in it and I was wondering if metal tape would be okay to use to cover them or if it would eventually come loose and get sucked in to the motor?
Long story about why I have a throttle body with holes in it but I know it's been causing my idle surge.
LS1Tech Administrator
Received 1,483 Likes
I've always used JB Weld. Before I had LS1 Edit for my WS6, I used to change hole size in my TB all the time till I got the idle where I could stand it with my cam.
The JB Weld worked fine. It never fell out, and I could drill through it again without issues.
Originally Posted by rbrcka
If you clean it good, the JB should take care of it for sure.
