How hard can you spin a 402?
I've gotten over 1000/1000 at the motor..On an aluminum LS2.
diamond pistons, h-beam rods, arp rod bolts, and arp main studs.
Originally Posted by Bandit28
I was wondering more along the lines of how much power can i produce and everything stays together
Originally Posted by 2c5s
WOW, is it STILL running or in pieces?
But you knew that already.
The motor istelf was as tight as a drum. And didnt leak or burn a drop of oil.
I tore the motor down in order to lower the compression. As well as diagnose a "Valvetrain" problem. NOT a motor problem. You fuking moron.
But you knew that also...
I wish I could have said that about the motor that YOUR tuner ripped me off and fuked me out of.
Dont you remember??? You know, the one that took me for 23 grand but sold me a busted *** 1997 LS1 that leaked oil EVERYWHERE..(All the while, passing it off as a practically NEW forged LS6.) But then tried to cover it up by sending me ANOTHER busted *** motor.
BTW, Heres the graph of the motor that you think was "Bad"
Do you want me to post pictures of the car in Pamona at a show a day BEFORE I pulled it apart to prove to you that it was running/driving??
Again, UNLIKE the condition of the last motor..
Quit swinging off the ball sack of your tuner. It makes you look like a bitch.
For those of you who dont know. This troll follows me around and tries to make things out to be what their not.
Its in pieces now.
Oh, if you feel that inadequate that you need to "prove" something to me, knock yourself out!! Can we say little p.p.?
So your engine is in pieces, sucks to be you.
LS1TECH Sponsor
Its in pieces now.
