Exhaust that exits through the body.....
Old 03-06-2007, 11:27 AM
6-SpeedZ's Avatar
Default Exhaust that exits through the body.....
My buddy has been looking for an exhaust tip that actually needs a hole cut in the body for it. Almost like the marine applications where they exit through the hull. I know I have seen them on here before in different posts, but cant find anything now. Please post up some links if you have anything.
Old 03-07-2007, 10:35 AM
6-SpeedZ's Avatar
Someone has to have seen this before ???
Old 03-07-2007, 11:03 AM
thunderstruck's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/656362-true-3-dual-side-exit.html
found it, lol only 16 pages back. i knew i had seen one recently
Old 03-07-2007, 12:10 PM
6-SpeedZ's Avatar
Thanks for finding that for me ! But, I am looking for something that is a production unit that can be purchased. It is for a pickup truck, and could actually be bigger that that one, or have two pipes in one unit. Anything that can be ordered would be cool. Thought I had seen one for a newer Dodge Ram at one time.
Old 03-07-2007, 12:21 PM
Tainted's Avatar
no one that I know of makes one that exits throug the body, its all custom done
Old 03-07-2007, 02:50 PM
King James's Avatar
Are you talking about these?
If so, check out the exhaust tips at stylinconcepts.com
Old 03-07-2007, 03:26 PM
ICRAZY6's Avatar
Thats the same style that they put in a pickup on Trucks on Spike TV. Looked really good.
Old 03-08-2007, 10:25 AM
6-SpeedZ's Avatar
That is exactly what I was talking about. Thanks alot !
Now, has anyone seen that style tip without the two tips inside it ? I am talking about just one big opening. Thanks for the help on this guys!
Old 03-08-2007, 10:47 AM
SS4Luck's Avatar
good luck, that would definatly end up just ebing custom work...
Old 03-09-2007, 10:48 AM
6-SpeedZ's Avatar
I dont know why you would say that, as it would be alot less work than the pic of the one posted here. Anyone else ???
Old 03-14-2007, 10:13 AM
6-SpeedZ's Avatar
Anyone?
Old 03-14-2007, 11:50 AM
00slowredz's Avatar
never seen it done, good luck though...i definitely wanna see pics if you do it!
Old 03-17-2007, 03:36 AM
lazylongboarder's Avatar
I've been thinking about the same thing and just thought of an idea.
What about taking a larger header flange, chroming it and bolt it on inside out. I'll post a pic asap.
Old 03-17-2007, 03:44 AM
k here it is. Mounted inside out, chop it short, only the larger side flange mounted on the outside of the body to give that custom rolled look, and have your pipe sticking out the middle.
It's what i'm doing on my LS1 powered porsche 911. Good luck with you project.
