93LT1 with 700R4 from a 91
Old 03-06-2007, 06:14 PM
RS_Maro's Avatar
Default 93LT1 with 700R4 from a 91
I was wondering if I had to mod anything to get a 700R4 to fit a 93 LT1...or should just try to rebuild the original tranny?....any advice would help and if you know what mods are needed plus add them also!!!
Old 03-06-2007, 08:49 PM
modracr62's Avatar
Only thing that i ran into is that plug for the trans was different. I think the 4l60 (not 4l60e) used a different valvebody.
Old 03-06-2007, 10:37 PM
LS1Tech Sponsor
performabuilt's Avatar
it can be done you will need to change the plug and a little internal wiring , the valve body is a little different but it can be used .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
