Ran into a problem installing sway bars...
I got the front bar off ok, but when I went to put the new ones on I found out that the old bolt that goes through that U clamp into the weld nut, doesn't fit through the clamp. Long story short, if i had to drive my car without the front sway bar in how bad/ dangerous would that be?
Thanks
Thanks
I would not drive it. It a straight line it would be fine, but If you had to make a suddne turn or maneuver, you would under steer like crazy. If you absolutely HAVE to drive it somehwere, drive slow and take corners even slower.
LS1TECH Sponsor
Just take a rat-tail file and make the hole a little bigger... pretty simple and common with stamped parts.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
