229/229 575/575 cam and 1.8 hs rockers too much lift?
Old 03-06-2007, 11:49 PM
383camaroSS's Avatar
Default 229/229 575/575 cam and 1.8 hs rockers too much lift?
i have a 229/229 575/575 cam and 1.8 harland sharp rockers...will this combo make it to much of a lift? i keep blowing head gaskets...this is my second pair ive blown...first i had copper and then went with cosmetic and they still blew what is wrong any oppinions?
Old 03-07-2007, 09:54 AM
GR33N GoblinM6's Avatar
cosmetic head gaskets... hmm.. who sells those.. Mary Kay? or the Avon Lady?
Old 03-07-2007, 10:52 AM
vettenuts's Avatar
If you are losing a head gasket, not sure why you are suspicious of the valve train setup. Have you checked the deck/head for flatness? Always the same gasket? Were the surfaces perfectly clean prior to installation?
The GM MLS gasket is pretty forgiving, sounds like you haven't used those.
Old 03-07-2007, 05:27 PM
JPH
JPH's Avatar
n/a motor, sounds like you are not trqing them tight enough, or a bad tune?
