5.3L Block (LS4?) bore to 5.7L for FI?
Old 03-07-2007, 02:08 AM
mahhddgtp's Avatar
Default 5.3L Block (LS4?) bore to 5.7L for FI?
I've heard a few people talk about doing this... Basically getting the smaller motor and boring it out, while still allowing there to be more meat on the cylinder walls.. And I think there's a shorter stroke allowing more revs, but I'm not sure..
I've been curious, has anyone on here done this setup? Are the stated benefits above correct?
Old 03-07-2007, 05:40 AM
cablebandit's Avatar
what you would be getting is a iron 5.7. Stroke is the same between the 2. This would be a good idea for someone who wanted the strength of iron but wanted to keep the cubes stockish.
Old 03-07-2007, 02:12 PM
motorbuilt's Avatar
With the money in machine work your spending on boring the block that far.
I think it would be foolish to not just use a $300-$400 6.0L block and get the large bore size instead.
Old 03-07-2007, 02:34 PM
black98ws6ta's Avatar
Also after they get done boring the 5.3 block out there is less material there then a 6.0l iron.
Old 03-07-2007, 04:28 PM
really? i did not know that. If you are using a small turbo....or limited in turbo size (think incons here) the smaLLER cubes will be better....say 346 vs 408 as the bigger cubes will choke on a smaller turbo
Old 03-07-2007, 04:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Don't waste your time, get a 6.0 block and be done with it.
Old 03-07-2007, 05:07 PM
kp
kp's Avatar
I think he is talking about the aluminum 5.3 block. I have read that the aluminum 5.3 and newer 5.7 blocks have exactly the same sleeves and its no problem boring them to 5.7 size.
Thats what I remember reading anyhow. Crapload of 5.3 aluminum blocks were floating around a couple years ago cheap if I recall and thats why it was brought up.
Old 03-08-2007, 02:43 AM
mahhddgtp's Avatar
You and another fella were the ones who got me thinking about the idea. I was just trying to clarify the reasons for it all.
I know about the turbos choking out on a large motor.. If I ever got my hands on an Incon kit, I'd definitely keep stock cubes, or even less...
Ah ok. Makes sense.... So I guess scratch that off the list of FI ideas.
Quick Reply: 5.3L Block (LS4?) bore to 5.7L for FI?
