FI Vette owners, How did you do your fuel system?
Old 03-07-2007, 09:56 AM
nmp27's Avatar
Default FI Vette owners, How did you do your fuel system?
I've just got my 402 up and running (8:1, good parts) and I currently have a LPE intank pump, alkycontrol, and a MSD boosta pump (not installed yet) I understand from my readings that this should limit me to 700-750.
Outside of the ECS fuel system, does anyone have any safer ideas that will work to support more HP?
Thanks!!!
Nick
Old 03-10-2007, 06:21 AM
EPP
EPP's Avatar
We started out with the '97 C5 fuel line set-up that has a return line on this C5 that we built the engine for, and added twin turbos.
http://www.exoticperformanceplus.com...Car.php?car=26
We were making close to 800 rwhp with it. Here is a video of it.
http://www.noobzor.com/epp/ttvette.wmv
If you listen closely, you can hear the tires spin on the dyno in 4th gear, right before we lifted. We saw 790 rwhp, but we're sure it was making plenty more, if we wouldn't of had to lift.
I prefer the ECS fuel system, and if you install it the way we did on this C5, you won't have any problems with it.
http://www.exoticperformanceplus.com...Car.php?car=40
The ECS system will be able to handle more power than using the system we did on this turbo car three years ago. Bob
