what stall is good for my setup
Off the top of my head I say a 4000 stall will be good on that setup. But it would be helpful to know what gears you're running. It would also help to know what this car will be used for.
Street driving only, strip only, street-strip but mostly street, street-strip but mostly strip, ect.
Are you considering spraying this car ever?
Originally Posted by 1f8lLs1
I have 3.73 gears and i'm planning to spray a 150 shot. I want it for street-strip but mostly street want do you think?
Here's a link:
http://www.converter.cc/converters/street/GM/1/main.htm
Call Yank and ask them which of thier converters they like for your setup. Good luck.
i have a 3600 stall but should i go bigger or my should be good?
I would still give Yank a call and see what size they recommend.
Originally Posted by darrensls1
Based on that I like the Yank PY3600. It's a good N20 converter and should be ok with your NA specs as well. You can probably get away with a SS4000 even on the spray but I'm not sure how much you'll like that big STR on a mostly street car.
Here's a link:
Here's a link:
SS4000 would be ok for the street, it's only .05 more STR than the one I'm running. With shorter gears it will be more friendly on the street since you won't need as much gas to get moving but the SS series are pretty tight converters.
