Porting a FAST
Old 03-07-2007, 12:30 PM
SEB
SEB's Avatar
Default Porting a FAST
Is it really worth the extra $$$$ to port the FAST intake or should I save my money. I have some 1.5 TEA 5.3 heads that are milled to 58cc. I will be running N/A with no Power Adder at all.
What do you thinK?
Should I port THE FAST or just bolt it up?
Old 03-07-2007, 12:42 PM
WizeAss's Avatar
What do you thinK?
are your heads flowing more than what the fast unported can handle. I seriously doubt it unless they flow over 330cfm......... I am sure you will gain something but the HP/$ may not make sense.
Old 03-07-2007, 12:43 PM
V6 Bird's Avatar
Yes port it. with porting the intake correctly and the TB as well (TB alone was worth 15 hp on FAST's testing of the one I sent them) you can see gains of 25-35 hp.
Old 03-07-2007, 12:47 PM
WizeAss's Avatar
Mike.... what cfm does the stock fast **** a brick at?
I know the LS6 starts lacking around 270-280, I figured the unported fast would be good for around 300-315 cfm or so right?
Old 03-07-2007, 12:48 PM
SEB
SEB's Avatar
Thanks, I was thinking the same thing. But I wanted to ask first. My heads might flow just over 300 cfm on the intake if I am lucky.
Old 03-07-2007, 01:09 PM
slayer_taunu's Avatar
talk to Shaner at the meet on wed.
Old 03-07-2007, 01:27 PM
V6 Bird's Avatar
LOL
Mike I dont know really off the top of my head. Chris does though. Thats why we ported Davids before installing it.
Old 03-07-2007, 02:15 PM
Omega Doom's Avatar
where is a dyno shop close to mesquite?
Old 03-07-2007, 02:17 PM
SEB
SEB's Avatar
I think Speedtek has a dyno. But I think it is a Mustang Dyno & heard nothing good about Speedtech either.
Old 03-07-2007, 02:21 PM
Omega Doom's Avatar
not at the buckner location?
Old 03-07-2007, 02:35 PM
SEB
SEB's Avatar
I could have swore they had a Dyno. I guess it got re poed.
Old 03-07-2007, 02:37 PM
V6 Bird's Avatar
It was moved to the Hurst location.
Dallas Mustang has a dynojet Roy. You know that! Our boy works there foolio!
Old 03-07-2007, 02:51 PM
Omega Doom's Avatar
yea, I know but he is STILL hard to get ahold of! I will probably go there as soon as I speak the with KING!
Old 03-07-2007, 04:39 PM
1LSWON's Avatar
I was wondering this as well. My heads flow 340CFM @ .600, would I see gains with a ported fast?
Thomas
Old 03-07-2007, 04:42 PM
beardWS6's Avatar
Thomas
Did you ever get the Kooks from mike?
Old 03-07-2007, 04:45 PM
1LSWON's Avatar
I have to get those bad boys thrown on, but my car is in the body shop right now, and I'm not sure how long it will be in there. Yeah I can't wait to see what those bad boys do for me. What do you think about porting the fast yeah or nay? Also do I have to take the heads off of the car etc. cause if that is the case I will not do it.
Thomas
Old 03-07-2007, 05:05 PM
beardWS6's Avatar
Thomas
I would have it port matched to the heads. But they can do that with them on the car.
Old 03-07-2007, 05:54 PM
xfactor_pitbulls's Avatar
You do not need to port match to the heads. Taking the port out to the index line is good enough, if your head is still larger it does not matter, because you will break through the casting. You also will gain HP even from a set of heads that flow 280, please keep the talking out of your *** stuff to yourself.
Old 03-07-2007, 07:44 PM
WizeAss's Avatar
Thomas
without a doubt..... you better do it!!!
Like Brandon said.... you will gain even with heads that flow 280..... mainly due to the fact that the extra intake flow will help at lower valve lift points. I just dont see how it is as benificial on a setup that has 280-300 cfm peak vs one that does more? Since the intake is not a restriction until XXX cfm.
again we are talking HP:$ here...... how much are you talking about spending to have it ported?
Old 03-07-2007, 07:49 PM
WizeAss's Avatar
I still standby this statement, unless someone has proven gains for heads that flow 300cfm or less at .600????
Quick Reply: Porting a FAST
