Need Specific info with LS1 Edit
Old 03-07-2007, 04:20 PM
engine_run's Avatar
Default Need Specific info with LS1 Edit
I need some help. I bought LS1 Edit that is still attached to a 99 M6 PCM. I need to either find the same segment number from a 99 but with a A4 or maybe someone with HP Tuners for a 99 and tune the PCM to be a A4. I am in Dayton so the HP Tuners idea will most likely be a problem. I have been emailing the Edit guys and they are saying I gotta find a segment nubmer that is the same as mine. The idea of using a HP tuner for the 99s is just an idea, sounds like it might work but if any one has any ideas I could sure use it! I am trying to use this PCM in my 00 A4 car for a tuning PCM. The specific file is "Segment 1 9360361".
Any help would be MUCH appreciated!!
Old 03-07-2007, 06:22 PM
N126's Avatar
Does Ls1s idel in open or closed loop and at wide open throttle are they open or closed loop?
Old 03-07-2007, 06:29 PM
LS1TECH Sponsor
foff667's Avatar
idle closed loop unless at startup or commanded otherwise.
open loop at wot unless commanded otherwise...although some trucks in stock form will stay in closed loop for a few seconds even at wot depending upon how long their delay timer is.
