Check Engine light on and blinking
forgot to add i just found out the same day the light started blinking i have my rear o2s in the front. I just added new intake tb lts ory,tr6s and wires. The tune is comming ive been putting around nd its been running like crap then sunday on my way home it acted like the car wasnt running on all 8, what could it be
If it's blinking it means there's a misfire. A-Zone can likely tell you what cylinder it's on and then you can swap the plug wire or coil from a good cylinder to see if one of those is the culprit. If it is, the misfire code will more to a different cylinder
my friend accidentally plugged his rear O2s in the front and the only thing it really did was make it run rich and his gas mileage sucked really badly, im talking 150 miles a tank. i could see it fouling up some plugs if you did this and that would be the worst case i think, but you never know.
a blinkin light is a missfire. re-check all plug wires and check the plugs. thats or a fuel injector. maybe a wire was barely on and when u hit wot it kicked it off... where are u located?
