LT1 Supercharger Question
Old 03-07-2007, 07:10 PM
87Lt1Monte's Avatar
Default LT1 Supercharger Question
I have a 383 Stroker Eagle 4340 Crank and rods and SRP pistons. It was gapped to a near stock gap But a good set of rings. With a A2W intercooler how much boost could i push safely? thinking of using a S trim.
Old 03-07-2007, 07:47 PM
Ed @ Late Model Speed's Avatar
Your compression ratio will be what determines how much boost your engine can take before it detonates. If the 11.1 in your sig is the car in question, then I would say about 7-8 psi would be the max you could run without detonating. You may be able to run a little more boost if you run a meth injection kit.
Hope this helps,
Ed
Old 03-17-2007, 12:43 PM
87Lt1Monte's Avatar
What about without an Intercooler? I will run a 75 shot at the racetrack to cool the charge. Do you think i should pull the heads and get a thicker head gasket? i mean the motor is not in the car yet.. Another question is with a small dish piston .030 head gasket and a LT1 head. i think it was calculated just under 11 to 1 and i want to drop a whole point. is it possoble with a thicker head gasket? I have seen as thick at .080 SCE Copper.
Old 03-17-2007, 07:21 PM
DeltaT's Avatar
You don't want to go much above a .040" gasket, especially if your piston is down the barrel at all at TDC. You need good quench which should be in the .030-.050" range from the piston top to the head deck. Otherwise you could get worse detonation even though the CR is lower.
Dished pistons would be your best bet - like a set of SRP blower pistons.
Jim
Quick Reply: LT1 Supercharger Question
