Rear turbo oil return pump recomendations
[SIZE=5]Ok heres the jist of it. I am piecing together a rear mount turbo kit on my chevelle and need to know what to do about a oil return pump.I made the mistake of trying to use a fuel pump and oil cooler with bad results. Jus wanting to know what you guys with rear turbos are running or what the manufacturers are using . Thanks Mako
A lot of guys use this pump as well as my self. I have not mounted mine yet though but about to I will tell you how it works.
http://www.racerpartswholesale.com/mocal1.htm
That's the one I bought as well. Someone recommend using -10 line for the return. Do you guys think a line that big is nessary? The outlets on the Mocal pump are smaller than -10 line. I do not want to run that big *** line on my car! What size comes on the sts kits?
Brian
Brian
