getting a clutch what else
Ok so i have 60,000 miles on my car and i'm getting an ls7 clutch kit with ls2 flywheel. I want to know what else i should get with it do i need bolts bearings what else? i going to have a shop install this because i don't have the time and tools to putts with this. should i also have the drill mod done at the same time?
Originally Posted by Y2K SS
slave is basically your throw out bearing. I wouldn't worry about the master unless its giving you problems.
The new slave will come with a new T/O bearing. And I agree, dont replace the master unless its giving you problems. Its no big deal if you need to replace it further down the road because it doesnt require dropping the trans.
