SES light
SES light
i plugged my car in tonihgt came up as misfire in mulitply cyenders, i think is what it says, i rember it not being one but sayin it was one but diffrent one each time or something? It was blinking,
okay so you ditched the front O2's and you plugged the rears into where the fronts go? If so then that will cause a light too. You MUST have your front O2's plugged in and functional. If you just put the rear sensors in the spot of the fronts and plugged the clips for the fronts in then I would think it would work okay. Not sure if the rears are a different part than the fronts.
