Autozone - Spring compressor?
Old 03-09-2007, 09:31 AM
tuffass's Avatar
Default Autozone - Spring compressor?
I'm going to be putting my springs in tonight and autozone has the rental compressor that looks like a small rectanular C-clamp with a little T bar to lossen tighten it on the top or side however you look at it.
Has anyone used this before? how did it work out for you on the # 8 cylinder?
Old 03-09-2007, 10:07 AM
tuffass's Avatar
Its pretty similar to this. Only diff i think is the T handle instead of the round **** this one has.
BlackHoleSunSS's Avatar
Get the crane cams dual compressor, or better yet, borrow one. My buddy broke a ******* bolt into his head with that VatoZone one.
Old 03-09-2007, 10:16 AM
tuffass's Avatar
I'm looking for something that i can pick up tonight. My car has to be up and running tomorrow so I'm not going to be able to order anytyhing.
How did he break a bolt anyway? These dont attach to any bolts.. Are you talking about the one thats a flat peice of steel that you use the rocker bolt holes to srew it in for an ancor? I could see how that one would break a bolt.
Old 03-09-2007, 10:25 AM
thunderstruck's Avatar
i used that one on my spring changes after the first lever type one i bought got bent up. i have only used those two but this one picture worked pretty good for me i thought. and they were single comp 918's, dont know how it would work for dual springs
Old 03-09-2007, 11:11 AM
tuffass's Avatar
HAs anyone eles used this for dual springs?
What about this one?
Old 03-09-2007, 12:04 PM
Blk97WS6's Avatar
Dont know how either work, since ive only used the crane tool, but by looking at the first one, i dont think theres any way your going to be able to use it on the #8 cylinder.
Old 03-09-2007, 12:25 PM
YellowMonster87's Avatar
only one way to find out......good luck with it and keep us posted
Old 03-09-2007, 12:41 PM
dub.ya.es.SICK's Avatar
also curious! post up
Old 03-09-2007, 12:44 PM
tuffass's Avatar
Okay well after stopping by 2 performance shops and none having any type of compressor, I bought this one from napa for 11.00. I'm going to whack the handle off and hope to god that it works okay.
I'll post tomorrow how it goes.
Old 03-09-2007, 01:08 PM
Studytime's Avatar
Ouch... changing springs on the car is enough of a pain WITH the correct tool. Best of luck man.
Ben T.
Old 03-09-2007, 01:13 PM
tuffass's Avatar
Ben T.
I've read where several people have used this. Might take a little longer but why else wouldnt it work? I'm going to cut the handle off so it's just a square that i can bolt on.
I might even still rent that one from autozone to do all of them except the rear ones. I know that tool wont fit back there and this one should easily.
Old 03-09-2007, 02:00 PM
vettenuts's Avatar
I wouldn't use it. High performance springs are surface treated, if you scratch it the life will be shortened. Get a tool that presses on the retainer only.
Old 03-09-2007, 02:30 PM
tuffass's Avatar
Err.. thats exactly what this tool does. it never touches the spring.
Old 03-09-2007, 02:41 PM
pray you dont break any bolts now...good luck
Old 03-09-2007, 02:57 PM
tuffass's Avatar
I'll definately be doing this part myself and taking my time.
My buddy that's helping me with "Certain things" can get a little ahead of himself at times. He seems to want to ignore what the HOWto guide says to do because he knows a better way!
Maybe thats why his car hasnt touched pavement in about a year
Old 03-09-2007, 07:47 PM
vettenuts's Avatar
OK, sorry. I saw the photo of the Autozone one above
Old 03-09-2007, 10:13 PM
Hell'sChariot's Avatar
I ordered the crane tool. Everybody seems to love it, and say its the easiest to use. So I figured the cost will be worth it in the end.
Old 03-09-2007, 10:23 PM
Blk97WS6's Avatar
are you going with dual springs?? If so be EXTRA careful not to break any bolts.
Old 03-09-2007, 10:25 PM
bigdsz's Avatar
Go to the tool section and search for "Tims tool". It is cheap and very easy to use. The Autozone tool is a PITA to use. Getting the keepers back in can be difficult.
Quick Reply: Autozone - Spring compressor?
