Morel Link bar lifter pics
Old 03-09-2007, 01:44 PM
Tom@SpeedInc's Avatar
Default Morel Link bar lifter pics
Heres a picture of new Morel Link bar style lifters for LS1/2/6 motors
Let us know if you need anything?
Available Hydraulic or Solid
$529 for hydraulic.
Discuss
Old 03-09-2007, 02:35 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Sweet...gonna have any dyno numbers or any way to show improvement over the stock style lifters/lifter trays?
Old 03-09-2007, 03:36 PM
Cstraub's Avatar
Thanks Fraser....
Old 03-09-2007, 05:30 PM
JunkyardZ's Avatar
Nice looking piece! What are the advantages over the stock type lifter?
Are these for high hp applications only?
Old 03-09-2007, 10:55 PM
These are stock style lifters with a link bar instead of using the lifter trays.
Ideal for high rpm race engine, no chance of of the lifters rotating.
Same billet lifter bodies and quality you would expect from Morel.
Old 03-09-2007, 11:41 PM
97BlackLT1TA's Avatar
def a nice looking piece
Old 03-10-2007, 12:12 AM
Greg Fell's Avatar
how much are these going for?
Old 03-10-2007, 01:32 AM
JRracing's Avatar
No offense jack *** but is says it at the bottom of the thread.
A very nice peice.
Old 03-10-2007, 02:53 AM
PREDATOR-Z's Avatar
sweet, but how does this design affect conventional cam only swaps (if you have them and decide to chage cams). with trays out, the lifters have nothing to hold them, on the other hand they wont drop in pan. Hmmm, magnet pens will work, but how about dowels (would be a pain advancing dowel lobe by lobe, if that works).
I think a special tool to hold the lifters (old and those morrels) should be designed.
Kinda like a comb shape in alum with screw on strong magnetic tips (so they dont separate as is sometimes the case with pens)
Old 03-10-2007, 09:47 AM
Even if one did fall you could just drag it back up with a magnet
like you said no chance of it fall in the oil pan.
Old 03-10-2007, 10:05 AM
PREDATOR-Z's Avatar
Yeah I know, it is just I don't know why someone doesn't make a tool that holds all the lifters (regular and these) at the same time.
I've seen many posts over the years with cheap magnets that separate from the pen and get stuck to the lifter. Pita to get out.
What is the preload range on these babies?
Old 03-10-2007, 10:18 AM
stealth71's Avatar
Look good. Thanks for the pic.
+1
Old 03-10-2007, 10:23 PM
Greg Fell's Avatar
A very nice peice.
it does now. you certainly have a way with words...no doubt very clever.
Old 11-06-2007, 06:46 AM
Blorton's Avatar
Bringing this one back from the dead....
Has anyone been running these? How's the long term picture working out?
Looks like a great set of lifters.
Thanks,
Dan
Old 11-06-2007, 09:17 AM
vanilla89's Avatar
How much more do these wheigh than a ls7 lifter???
The link bar has to add wheigh to the valve train..
Old 11-06-2007, 09:30 AM
Greg Fell's Avatar
i think most feel its not as important as 'weight over the nose' portion of a rocker. not saying it doesn't matter though
Old 11-06-2007, 09:47 AM
Cstraub's Avatar
The added weight is far out wayed by the lifters performance.
Old 11-06-2007, 03:30 PM
DONAIMIAN's Avatar
How much do the solids run?
Old 11-06-2007, 06:36 PM
eallanboggs's Avatar
You can do a cam swap using link bar lifters just like you can with lifter trays. The lifter trays do help hold the lifter up somewhat during a cam swap, but that isn't the intended purpose of the tray. The tray is supposed to keep the lifter from rotating as does the link bar, not hold the lifters up. You won't read anywhere in a GM shop manual where it says you can do a cam swap and depend on the lifter trays to hold the lifters up. GM doesn't endorse this method. They'd tell you to first remove the intake and heads to do a cam swap. During a cam swap with link bars you would have to use a rod or dowel as most people now do with lifter trays notwithstanding those few brave souls who have enough nerve to do the cam swap using the russian roulette method.
Old 11-06-2007, 08:39 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'd like to hear from anyone who is using these and gotten rid of the lifter trays. Also any comments about oil drainage vs with the trays.
Quick Reply: Morel Link bar lifter pics
