Born on date?
Old 03-09-2007, 08:17 PM
PDQ-TA's Avatar
Default Born on date?
I have my Asc# and conversion date But was wondering how to find out when the car was built in the factory
Old 03-09-2007, 09:25 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
The decal on your driver's door will tell the month/year.
If you contact phs-online.com, you can get the exact day of assembly. Mine was July 1, 1999. The decal on my door says 07/99.
Old 03-15-2007, 01:01 AM
Grendel123's Avatar
what if there is no decal on the door? I know the car had some work done on it and I believe the door was either replaced or repainted, so no decal. Is there another way I can get that information? Thanks in advance.
Old 03-15-2007, 08:13 AM
Rick99TAWS6's Avatar
Found mine on the Manifest sheet(build sheet which was dated a few days prior to the build) - found it in the car after original purchase(has all of the RPO codes including some not on the door sticker
Old 03-15-2007, 09:47 AM
mapleredt/a's Avatar
Give me your vin.
Old 03-17-2007, 02:44 AM
NDFORSPD's Avatar
I believe I have the same sheet as Rick has, the car apparently started on May 21(coincedentally My b-day), and had a final out date of May 26, how long did yours take to make rick? I thinki mine was thru a weekend/holiday for that yr, but still took 3 days on the line
Old 03-17-2007, 03:13 AM
SpaZMaN's Avatar
November 9th, 1998 here. i went to the dealer and got the info.
Old 03-17-2007, 09:33 AM
Rybo Flavin's Avatar
For those of you who don't have the door sticker, build sheets, or any other documentation there may be an answer for you. I recently did this for my 1981 Camaro and I was most impressed.
Send an email to the GM Media Archive vehicleinvoice@gmmediaarchive.com , making sure to include your name, contact information, and your VIN. They have EVERY GM car dealer invoice stored and they will send a copy of the original dealer invoice to you for $50. I know that sounds like a lot of money, but for me it was well worth it to get the info for my 81 Camaro.
They are backed up a few days, but they will contact you to get your payment information. Then, they will either email or postal mail a copy of the dealer invoice to you.
Old 03-19-2007, 09:03 AM
The manifest date was 11/19/1998(think this is the date the manifest sheet is printed) and GM build date was 11/23/1998 - sheet has all of the RPO codes also including some not appearing on the door sticker
Old 03-22-2007, 03:12 PM
wamp42's Avatar
Ive heard of people finding their build sheets attached to the top side of their gas tank or something like that. Any truth to this?
Old 03-22-2007, 10:41 PM
PowerPro01's Avatar
Gas tank sticker is de rigeur for Vettes.
The Manifest Sheet (or Build Sheet) is the actual instruction sheet that goes with the car, down the line. The codes are what the line workers use to pick and place the actual parts and pieces on the assembling vehicle. It's printing date will precede the actual "finish" or "completion" date, which is the date that appears on the Dealer Invoice. Actual build time varies, but is seldom more than two working days...
Old 03-23-2007, 11:48 PM
joshp14's Avatar
I can also run a GM VIS for you with your VIN and give you the build date from GM. Its usually a few days before your ASC conversion date.
Old 03-24-2007, 12:35 AM
teh PuRpL3z
DrEvyl's Avatar
'98-00 took about 4.5 days. '01 and '02 took 5.3 days. My Formula was on the line from 8/19 to 9/2.
Old 03-24-2007, 03:04 AM
miamifan3413's Avatar
Joshp14 hooked me up with my info in a thread a while back....thx again
Old 03-24-2007, 09:09 AM
PowerPro01's Avatar
Ste. Therese was down to two, then one shift at that time...most other 3-shift plants take much less time...
Quick Reply: Born on date?
