Electrical Connection On TH400? Pic...
Old 03-10-2007, 01:17 PM
Dirty 30's Avatar
Default Electrical Connection On TH400? Pic...
Does anyone know what this connection is for?
"P" plug with one wire???
and
"B" bolt there, can I remove the bolt and install a temp sender there?
Old 03-10-2007, 02:12 PM
LS1Tech Sponsor
performabuilt's Avatar
yes you can put the temp sensor there it isnt the most acurate place though ,
as for the switchits kick down , passing gear , when power is applied in cars that had it originally it would cause the car to kick down to second and hold gears longer in drive
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-10-2007, 03:03 PM
Dirty 30's Avatar
so what should i do about that connection? oh and thanks!
Old 03-10-2007, 03:33 PM
LS1Tech Sponsor
wellif you want passing gear to work , Put switch on your gas pedal that will send 12 volts to it when you floor the car , Thats how it was done factory with the 400
__________________
Call 888-744-6542
Quick Reply: Electrical Connection On TH400? Pic...
