shouldnt i be able to download a tune to a RR...
Old 03-10-2007, 02:06 PM
7 Second Club
ty_ty13's Avatar
Default shouldnt i be able to download a tune to a RR...
i've got the roadrunner out of my car in my living room and im trying to load another tune on it... shouldnt i be able to do this with out it being hooked up to the car?
dont ask why its out of the car.... its easy to answer but not needed..
Old 03-10-2007, 02:07 PM
7 Second Club
ty_ty13's Avatar
i want to make sure i have all the firmware updates and calibrations corrected before i have it hooked up in my car.... because then ill be gettin in and out of the car for a few hours trying to figure out whats wrong if i dont have the calibrations right...
Thanks,
Tyler
Old 03-10-2007, 02:17 PM
ringram's Avatar
You need a proper bench flash setup with power, obdii, pcm connectors etc.
I assume you have all that?
Old 03-10-2007, 02:29 PM
7 Second Club
ty_ty13's Avatar
no... there is not power going to the roadrunner... just the dongle->usb
Old 03-10-2007, 03:48 PM
ringram's Avatar
= failure
You cant do that. You need the PCM connector with power to work the PCM.
Check out speartech. They do bench setups so you can work it out of the vehicle.
Old 03-11-2007, 12:24 AM
7 Second Club
ty_ty13's Avatar
Originally Posted by ringram
= failure
thats fine i just wanted to make sure that it was NOT saposed to work... cool... ill put it back in the car then
thanks ringram!
Old 03-11-2007, 03:56 AM
ringram's Avatar
No prob. You wouldnt have needed the OBDII, just the Power from the harness for the Road Runner.
Old 03-11-2007, 07:42 AM
TAQuickness's Avatar
I spoke with Craig about this. If your USB port supplies enough power, you can flash the RR while it's out of the car. This is only applicable with the USB connection. The BlueTooth option does require the PCM to have power.
Old 03-11-2007, 08:15 AM
Black02SS's Avatar
Yup. I have flashed mine countless times on the bench without a power source and it works just fine.
Old 03-11-2007, 09:51 AM
Coal Mining Director
onfire's Avatar
Same here.
Old 03-11-2007, 10:25 AM
Doc
Doc's Avatar
Dang! I thought my RR was the only one that could do it
Old 03-11-2007, 07:44 PM
slow's Avatar
I can do this with both my 98 roadrunner, and the 99-02 one I have.
Ryan
