After My Header Install.....
Old 03-10-2007, 02:54 PM
sickws698's Avatar
Default After My Header Install.....
after my header install i cant tell the difference if its ticking noise or rattling....If im over the engine i dont hear anything, every thing sounds sealed. but when i gut under the car i hear it(ticking/rattleing) sound...
Old 03-10-2007, 02:58 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
probably the collector to pipe [Y ? ] connection...did u use band clamps..if so..u might want to remove clamp....then take a piece of aluminum foil 3" x 2' feet or so and wrap the connection..then replace clamp..has worked on mine and others here.
Old 03-10-2007, 04:58 PM
sickws698's Avatar
its running open headers rite now
Old 03-10-2007, 05:13 PM
ArrestMeRed99Z28's Avatar
so it may just be valvetrain noise, get the exhaust hooked up and see it the noise goes away.
AJ
Old 03-10-2007, 05:37 PM
FireSilverLullaby's Avatar
Yeah its probley normal, take a vid
Old 03-10-2007, 07:00 PM
2_wacko's Avatar
I have the same problem.
Old 03-10-2007, 07:06 PM
Tainted's Avatar
what kinda gaskets did you use? all your bolts good n right?
Old 03-10-2007, 07:24 PM
Hell'sChariot's Avatar
Normal. The headers are alot thinner than the old iron manifolds. Its just valvetrain noise.
Old 03-11-2007, 10:32 AM
sickws698's Avatar
kk, now sincei have a missfire i have to go back and look at my passanger side ones( i put those spark plugs in before i installed that side heaader) thats the only possible side that one could of broke. is it possible to change passanger side with out removing the header?
Old 03-11-2007, 10:35 AM
sickws698's Avatar
One thing idk about also is, it only pops once when i get on it at 3000 rpms, its not like a constant missfire, its just a POP when it shifts then goes away
Old 03-11-2007, 10:37 AM
Hard Core Z28's Avatar
like hellschariot you will hear more ticking from valve train noise but if you getting pops sounds like you might have a leak or your 02 sensor is loose or even bad. Check them out.
Old 03-14-2007, 07:41 PM
Yeah i think i know what you mean about the pop, i got my car tuned and it went away completley, but i miss it. Its sounds like a small backfire when you shift.
Old 03-14-2007, 08:16 PM
sickws698's Avatar
lmaoo exactlyyy...so this isnt a broken spark plug?>
Old 03-14-2007, 08:20 PM
dyers98's Avatar
No ****! Does this really work or is it bs?
Old 03-14-2007, 08:40 PM
sickws698's Avatar
yah it deff works, ive heard that used on here many diff times.
Old 03-15-2007, 08:44 AM
dyers98's Avatar
I will give this a try. I have been wrestling with these short *** SPL collectors that won't seal for years. Thanks
Old 03-15-2007, 09:00 AM
WS6WRX's Avatar
I've been using the aluminum duct tape that you can get at the hardware store for this. It works great!
Old 03-15-2007, 11:10 PM
2_wacko's Avatar
After I check all the header bolts, band clamps etc, it tuned out to be a loose plug and wire no more tick.
