I started my Professional Products Typhoon swap today
Old 03-10-2007, 10:17 PM
98Camarod's Avatar
Default I started my Professional Products Typhoon swap today
Well today I took the plunge and started on the intake swap. I planned on finishing it in a day, but it didnt happen. I started at about 11:30 and had the intake off by 12:15. I used a shop vac to get all the dirt and leaves that clutter around the head bolts, and I scraped the stuff off of the heads.
I then took the ls1 coolant lines off and began to modify them. I dont think it is a very good idea now. I am going to see if I can get the ls6 coolant lines from the dealer on Monday. I cut it all up and used a t for each to connect the front to the back and I was going to run a line to connect the front and the back. I think it will be better if I just get the lines and do it right so it doesn't leak ( I dont even know what the ls6 lines look like or how they are routed).
I then put all the ports on the manifold and the map sensor which I had to modify the clip that holds it so the sensor was in the right direction. I then glued the gaskets so they would not move while I was putting the manifold on. While putting the manifold on, the oil pressure sending unit had broken and I noticed that the gaskets cover the intake ports on the heads. By now its 3:00 and I just have to give up because there are no places to get the items.
So tomorrow I am going to stick some rags in the intake ports and use my dremel to fix the gaskets. Hopefully Monday I can pick up the oil sending unit and ls6 coolant lines from the dealer. I have only taken one picture and thats with everything off and except the coolant lines. I will be taking more pictures as the install goes. I am hoping to wrap it up early Monday.
Old 03-11-2007, 12:57 PM
dlandsvZ28's Avatar
Save some money on the oil sending unit and get it at O'Reilly for $21.00
Old 03-11-2007, 01:14 PM
thunderdan74's Avatar
It desn't use the stock o rings for the intake ports?
Old 03-11-2007, 02:27 PM
98Camarod's Avatar
I get it on a commercial account, and we dont have one of those around here. I am assuming youre talking about the injectors, and yes you just reuse those with some oil.
Old 03-12-2007, 05:46 AM
No, the big orings for the intake runner seals.
Old 03-12-2007, 08:25 AM
98Camarod's Avatar
No, it comes with gaskets. Its not plastic, its aluminum.
I now have to wait a couple more days to get my oil sending unit and ls6 coolant line and two plugs. Im thinking about just connecting the rear with some 5/16 fuel line instead of blocking it off. Good idea or not?
Old 03-12-2007, 10:49 AM
shudog's Avatar
thanks for the updates, can't wait to see it mounted. I haven't seen one of these pieces mounted yet!!! Just alot of hearsay floating around about these but I'm planning on getting one simply for the looks.
Old 03-12-2007, 10:58 AM
98Camarod's Avatar
Well mine was the satin finished and I painted it black. Since I'm waiting on these parts I went ahead and deleted my air pump and took some pictures of my duals and subframe connectors. I'll post them up soon.
Old 03-12-2007, 11:07 AM
bowtierodder's Avatar
i went through all the same problems you did and more with the install, i had to put the stock manifold back on twice before i figured out and worked through all the problems ....there was a thread about it somewhere on here.............good luck its a PITA
Old 03-13-2007, 08:40 AM
Sluggish's Avatar
any idea if I would have the same problems on an 02?
Old 03-13-2007, 09:11 AM
A-Dub's Avatar
I ran two LS6 front pipes, one on the front and one on the back. I used 7/32 (I think) coolant hose and a brass T to join the 2 pipes to the port on the radiator where the original vent tubes connected. Has been working fine for me for the last 1000 or so miles. I have an LS6 intake, but that shouldnt make a difference in this case.
Old 03-13-2007, 10:56 AM
depends if you get one of the newer production intakes, that has the better gaskets, and proper adapters to get it to fit without hitting the oil pressure sending unit. the first ones they shipped out didnt have this stuff, so i had to modify the gaskets like the other guy and wait for them to ship out the adapters after i called them. and on the manifold i got, i had to grind the front of it to let air enter through the iac valve because the manifold wasnt machined with the opening
Old 03-13-2007, 11:38 AM
shudog's Avatar
Old 03-13-2007, 08:20 PM
98Camarod's Avatar
The parts are supposed to come in tomorrow. My camera is in my car and I keep forgetting to grab it
Old 03-13-2007, 09:02 PM
98Camarod's Avatar
Anyone know what the small rubber hose is for on the back of the intake? There are three things plugged up in the rear, brake booster, map sensor and ?
Old 03-14-2007, 07:59 AM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
air system
Old 03-16-2007, 11:49 PM
Vacume source for the a/c controls. Or was it for the ***** pump, i can't remember!
Old 03-17-2007, 12:04 AM
Originally Posted by shudog
here are mine
Old 03-17-2007, 04:41 PM
gillbot's Avatar
man that bling hurts the eyes!
Old 03-17-2007, 05:57 PM
98Camarod's Avatar
Mine has no bling, but all I can say is **** those fuel rails. I finally got everything back together and let the pressure build up and fuel streeming out of EVERY injector. So after 3 times or trial and error I finally got it. I used longer bolts, and washers to shim it out. It would have helped better if the 4 brackets that hold it down where the same size each way.
I had to modify my HSW brackets to make them fit, and I trimmed the throttle body gasket. I just started it up and let run for a few minutes, there doesn't seem to be any leaks, vacuum or fuel. Tomorrow I'm going to let it run for a while and drive it down the road and see how it does.
Oh yeah, I found out the hard way that you SHOULD place the injectors in the manifold and then push the rails on starting from the BACK. I did one each way and putting the injectors in the manifold was far easier than trying to push them in with them on the rails. Yes I did use lubrication on them as directed.
As for the Professional Products Company, they have wonderful customer service and got me my parts next day air that did not come with my intake.
Quick Reply: I started my Professional Products Typhoon swap today
