TA's with STS kit....POST PICS!!!
Been searching around on here and a couple other sites and cant seem to find any decent pics of the STS kit on TA's....I can finds TONS on Camaros...
So if you have some pics of a TA with one post them up PLEASE!!!
Trying to see what it looks like from behind and how far it can be tucked up....Im also worried about being lowered it it, I dont scrape on anything now that I know how to drive a lowered car...
Oh I found one more here's how high you can tuck it up. My compressor housing is 3/4" from the heat shield. I also put an extra relective heat barrior on the factory heat shield.
Awesome....Im just very scared about scraping...I dont scrape on anything now and when I did (when I first had the car being lowered) I scraped the skid plate up front and the plastic air damn.
Originally Posted by enginjoe
Billy at TRT showed me how to tuck that thing up there so it almost disapears on my SS. I can't find the picture, but I know he has some. You can make it disapear on a firebird.
Originally Posted by koolaid_kid
I have a 97 Formula with the STS kit. Does that count? If so, I could take a couple of pics tomorrow. Just say what angle(s) you would like to see.
Im scared that I will scrape **** up being as low as I am....
either have pipes made up, or raise your car, as it will scrape. I have scraped mine and I'm the stock height. hell, even with custom pipes theres still a chance you will scrape. get rid of the lowering kit... lol. cuz ur gonna scrape
O.K., I'll try to get some shots today. You might check out EPP, Bob reported that he raised a lowered car back to stock height because it hung too low. I don't think that a side shot of my LT1 would help you, because my charge pipe goes up the driveshaft tunnel, not along the driver's side like the LS1. But the way the turbo hangs should be the same.
if you drive carefully, you wont scrape. my charge pipe hangs lower than anyone's i've seen, and i never scrape it. i am very careful when i hit bumps and leave driveways though..... oh yea, speed bumps are your enemy!!
they dont hang low at all as long as you do it right. Be alil creative work with the positioning of everything and weld a couple more brackets, i did it with a custom t70 master power rear mount, and the only thing you see from behind the car is mayyyybe the oil return fitting. But the MP t70 is bigger than what the Sts kits use. PS- My car is lowered 1" with hotchkis springs. NO PROBLEMS any where. My long tubes and y pipe(pacesetter) still hit before anything else do. Hope this helps!
yeah I have NEVER hit my y pipe, the only thing I have scrapped is my front air damn, I think Ill be find I just need to find a good exhaust shop that that can tuck them well.
